Why access point keep blinking orange/green and not connecting to Nebula
Zyxel_HsinBo
Zyxel_HsinBo Posts: 524 image  Zyxel Employee
Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - WLAN
edited December 2025 in Other Topics
If your Zyxel access point (AP) is blinking Orange/Green slowly (1-second interval), it means the AP is trying to connect to the Nebula Cloud but has failed to establish a stable connection. This issue is usually related to local network configuration or internet connectivity.
Troubleshooting Steps
1. Check if the AP Obtained a Local IP Address and firewall configuration
  • If the AP does not have a private IP address:
    Verify that your router, DHCP server, and Ethernet cabling are working properly.
  • If the AP does have a private IP address:
    Ensure your firewall is not blocking the required Nebula management ports:
    • TCP 4335
    • TCP 6667
2. Verify DNS Settings
To avoid DNS resolution issues, configure the AP or network to use a reliable public DNS server, such as:
  • 8.8.8.8
  • 8.8.4.4
3. Check Physical Connectivity
If the problem continues:
  • Inspect the Ethernet cable quality.
  • Check the uplink switch/router for instability.
  • Replace the cable or change ports if needed.
Still Having Issues?
If the AP remains offline after completing the steps above:
