How can I resolve PoE power shortages with the USG FLEX500H and multi-802.3at APs
Zyxel_HsinBo
Zyxel_HsinBo Posts: 532
Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - WLAN
image  Zyxel Employee
The USG FLEX500H provides only 30W of total PoE power, if you have more than
1 802.3at AP need to connect, here are recommended solutions to ensure the system stability:
  • Connect only one AP to the USG FLEX500H and the second AP to a PoE switch or a PoE injector.
  • Alternatively, power the second AP using the additional DC-in adapter.
  • Check and replace any faulty or low-quality Ethernet cables connected to the AP.
