How to Improve FWA710 Connection Stability with Weak 5G Signal ?
Zyxel_Jami
Scenario
Your 5G router experiences frequent disconnections and often appears to go completely offline when the 5G signal is weak, failing to switch to a stronger 4G network.
Configuration
- Enable Network Monitoring:
- Navigate to
Network Setting > Broadband > Cellular WAN. - Enable the
Network Monitoringfeature.
- Navigate to
- Set Preferred Access Technology to Auto Switch:
- Go to
Network Setting > Broadband > Cellular Band. - Set the
Preferred Access TechnologytoNR5G-NSA/4G (Auto Switch). This attempts to automatically switch between 4G and 5G.
- Go to
- Temporarily Switch to 4G-Only Mode for Stability:
- If the "Auto Switch" mode does not resolve frequent disconnections due to persistently weak 5G signals, temporarily configure the device to
4G-only modeoperate underNetwork Setting > Broadband > Cellular Band. This has proven effective in stabilizing connections when 5G is unreliable (e.g., 5G RSRP at -107 dBm compared to 4G RSRP at -69 dBm).
- Reposition the Device for Improved 5G Signal:
- To enhance future 5G performance, adjust the router's physical placement or orientation. Consider raising its installation height or moving it to a location with a better line-of-sight to the 5G base station. Optimal 5G RSRP is generally -80 dBm or better.
Apply for your Router.
These configuration changes are applied directly to your Zyxel 5G router via its local interface.
- 244 Nebula Ideas
- 6.9K Security
- 805 USG FLEX H Series
- 392 Security Ideas
- 88 Switch Ideas
- 60 Wireless Ideas
- 7.3K Consumer Product
- 330 Service & License
- 540 News and Release
- 106 Security Advisories
- 5.5K FAQ
- 89 About Community
- 124 Security Highlight
