How to move a Zyxel Nebula device to another organization?
Where to find
This process refers to actions taken within the Zyxel Nebula Control Center (NCC) to manage and transfer devices between different organizations.
Function description
The "Change organization" feature in Zyxel Nebula allows for the seamless transfer of a device from one Nebula organization to another. This is particularly useful when a user account owns multiple organizations and needs to relocate a device without issues, ensuring it is correctly assigned to the intended organization.
Scenario
A user needs to move a Zyxel Nebula Access Point (AP) from its current organization to a different target organization. The user's account is the owner of both organizations.
Configuration
- Verify Ownership: Ensure that your user account is registered as the owner for both the source organization (from which the device is being moved) and the target organization (to which the device will be moved).
- Utilize "Change organization": Within the Nebula Control Center (NCC), use the dedicated "Change organization" function to initiate the device transfer.
- Detailed Steps: For comprehensive, step-by-step instructions on how to use this feature, please refer to the official Zyxel Community guide: How to simply move a device to another org by using "Change organization"
Apply for each AP.
This procedure is performed for each Access Point or device that requires transfer. If you encounter any problems during the transfer, such as error messages or the device not appearing in the designated organization, please provide the following to Zyxel support:
- Screenshots of any error messages encountered.
- Enable Support Access for both the source and target organizations/sites involved in the transfer.
- 244 Nebula Ideas
- 6.9K Security
- 797 USG FLEX H Series
- 391 Security Ideas
- 88 Switch Ideas
- 59 Wireless Ideas
- 7.3K Consumer Product
- 327 Service & License
- 531 News and Release
- 104 Security Advisories
- 5.4K FAQ
- 91 About Community
- 124 Security Highlight
