Recommended Setup for Long-Range Point-to-Point (P2P) Wireless Links
Zyxel_Jami
in Other Topics
When establishing long-range Point-to-Point (P2P) wireless links, such as achieving approximately 300 Mbps over a distance of 1 kilometer or more, specific equipment and considerations are necessary to ensure stable and high-performance connectivity.
- Select an Appropriate Antenna: For long-range, directional deployments (1 km or more), a high-gain directional antenna (at least 14 dBi) is recommended to focus the wireless beam and improve signal strength. Omnidirectional antennas are not suitable for these scenarios.
- Choose a Compatible Outdoor AP: Use outdoor Access Point (AP) models that support external antenna connections via N-type connectors. The WAX655E is an IP67-rated model suitable for long-distance outdoor deployment and supports wireless bridge capabilities.
- Ensure Critical Technical Considerations are Met:
- Maintain a clear line-of-sight between the two points to minimize interference.
- Professional installation is strongly recommended for proper antenna alignment, accurate link budget calculations, and verification of regulatory compliance for transmission power in your region.
- 244 Nebula Ideas
- 6.9K Security
- 805 USG FLEX H Series
- 392 Security Ideas
- 88 Switch Ideas
- 60 Wireless Ideas
- 7.3K Consumer Product
- 330 Service & License
- 540 News and Release
- 106 Security Advisories
- 5.5K FAQ
- 89 About Community
- 124 Security Highlight
