How to Configuring SSID for VLAN-specific DHCP Allocation in Nebula Network?
In some networking scenarios, there's a need to ensure that clients connecting to a particular SSID are provided with an IP address by a specific DHCP server. While Nebula AP operate in a bridged mode and do not directly offer DHCP services, this guide will walk you through how to do so.
Topology and Scenario
Gateway (serves as DHCP server for specific VLAN) --- Switch --- AP
Configuration
DHCP Configuration: Ensure that the DHCP server on the gateway is correctly configured and actively distributing IP addresses.
Go to Site-wide > Configure > Access points > SSID advanced settings > select the SSID you want to assign specific VLAN.
Assign the VLAN that corresponds with the one set on your gateway in the VLAN ID column.
Verification
Connect a client device to the SSID. It should successfully obtain an IP address in the subnet with specific VLAN.
Noted
1. SSID-VLAN Mismatch: If clients are unable to obtain an IP, ensure the VLAN assigned to the SSID matches the VLAN configuration on your gateway.
2. DHCP Configuration: Ensure that the DHCP server on the gateway is correctly configured and actively distributing IP addresses.
- 241 Nebula Ideas
- 6.8K Security
- 755 USG FLEX H Series
- 379 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 320 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
