How do I enable roaming on my Zyxel Nebula network?
Zyxel_Jami
in Other Topics
To enable roaming on your Zyxel Nebula network, ensure that all access points broadcast the same SSID (including identical SSID settings and tags). Adjust AP placement and output power to create sufficient signal overlap, allowing clients to transition smoothly between APs. You can further optimize roaming by enabling 802.11r, 802.11k/v under Configure > Access points > SSID advanced settings.
- 242 Nebula Ideas
- 6.8K Security
- 764 USG FLEX H Series
- 385 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 323 Service & License
- 522 News and Release
- 100 Security Advisories
- 5.3K FAQ
- 91 About Community
- 121 Security Highlight
