Can I connect a single external antenna to both TS-9 ports on the FWA505 using a splitter?
Zyxel_Jami
Zyxel_Jami Posts: 246 image  Zyxel Employee
Zyxel Certified Network Administrator - WLAN Zyxel Certified Sales Associate First Comment Friend Collector
Connecting a single external antenna to the FWA505’s TS-9 ports using a splitter is not recommended and can lead to multiple performance issues.
Reduced MIMO Performance:
When both ports are combined through a splitter, the device may detect only one signal path, significantly reducing MIMO capability and lowering throughput, especially on higher-band 4G/5G frequencies.
Recommended Setup:
For optimal performance, use a 2x2 MIMO external antenna with two independent outputs, and connect each output to one TS-9 port on the FWA505. This preserves the device’s full MIMO capability and ensures the best possible signal quality and speed.
