Is it possible to set a data limit on an SSID?
Zyxel_JoyLee
Zyxel_JoyLee Posts: 201
Friend Collector First Anniversary
image  Zyxel Employee
in SSID
You can limit wireless client device traffic rate by configuring rate limits on a per-SSID basis.
This allows you to control the upload and download bandwidth for clients connected to a specific Wi-Fi network.
To do this, navigate to "Site-wide > Configure > Access points > SSID advanced settings" in Nebula.
Select the SSID you wish to configure and then adjust the download and upload rates in the "Rate-limit" section.
You can set different speeds for download and upload, or apply the same limit to both.
Additionally, if you need to limit traffic for specific VLANs, you can use the "Traffic shaping" feature under "Nebula >> Configure >> Access points". This allows you to create rules to limit the speed for a particular VLAN ID.
