Why Does My Access Point Enter Power Limited Mode?
Zyxel_JoyLee
If your access points are entering power limited mode, it is likely because the power supply does not meet the device's requirements.
For example, the NWA240BE requires a PoE switch that supports the 802.3bt standard for optimal operation.
If connected to a switch supporting only 802.3at, the access point operates in a limited power mode.
This leads to a reduced performance on the 5 GHz radio frequency (2T4R instead of 4T4R).
To resolve this issue:
- Ensure that you connect the NWA240BE to a PoE switch that supports the 802.3bt standard.
- Alternatively, use a power adapter with the following specifications: USB PD 15V/2A (Type-C).
- 244 Nebula Ideas
- 6.9K Security
- 805 USG FLEX H Series
- 392 Security Ideas
- 88 Switch Ideas
- 60 Wireless Ideas
- 7.3K Consumer Product
- 333 Service & License
- 540 News and Release
- 106 Security Advisories
- 5.5K FAQ
- 89 About Community
- 124 Security Highlight
