HIDE SSID does not work on BE radio
Zyxel_JoyLee
in SSID
When using WiFi 7 (802.11be) mode on the 5 or 6 GHz radio, the 'HIDE SSID' feature is not supported.
This occurs due to updated IEEE 802.11be regulatory requirements and the implementation of Multi-Link Operation (MLO) standards.
Therefore, this behavior is expected when the access point operates in WiFi 7 mode.
How to enable the 'HIDE SSID' feature?
To re-enable the 'HIDE SSID' functionality on your access point, you need to change the 5 GHz radio mode from WiFi 7 (802.11be) to WiFi 6 (802.11ax). Follow these steps:
- Navigate to Configure > Access Points > Radio Settings.
- Locate the Radio Mode section.
- Select 802.11ax for the 5 GHz radio mode.
For more WiFi 7 changes, please refer to below link:
Heads-Up: Latest WiFi 7 enforces new MLO change, Zyxel implement in 7.20! — Zyxel Community
- 243 Nebula Ideas
- 6.8K Security
- 783 USG FLEX H Series
- 389 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 325 Service & License
- 527 News and Release
- 101 Security Advisories
- 5.3K FAQ
- 91 About Community
- 122 Security Highlight
