How to see with WiFi Network a device is using
Matt_McG
Matt_McG Posts: 3
image  Freshman Member
Hi
I have recently received a Zyxel DX3301-T0 router from my broadband provider. I've set up a Guest Wifi Network using the web-based router management interface (192.168.1.1). This is in addition to the default main WiFi network. So I have two SSID's.
Using the web interface, I can see a list of connected devices with MAC address, IP address, etc. However, I can see no mention of which SSID a device is using. So I can't tell which devices are using the Guest WiFi and which are using the main WiFi. How can I find that information?
All advice greatly appreciated.
Thanks, Matt
  • Liba
    Liba Posts: 233
    First Comment First Answer Fourth Anniversary
    image  Master Member
    I can't find the relevant information in my router either. Perhaps this feature isn't supported.
  • Matt_McG
    Matt_McG Posts: 3
    Thank you for your reply Liba. Interesting that you cannot find that information either. I find it very surprising that such basic information would not be available in the web management interface.
