Port Forwarding is not working from Wan to Lan
Viols
Viols Posts: 2
image  Freshman Member
edited April 2021 in Security
I am trying to connect my Linux server from my home office to my workplace
There are no special security setting at my home WAN/LAN.
My workplace is using a USG110 with a WAN IP - e.g. 85.42.126.48
and my Linux server is MAC Binding to 192.168.1.49
for a security reason i have to pass through [85.42.126.48:9001] -> [192.168.1.49:22](TCP-SSH)
These are the setting I create in USG110
NAT rules
Port Mapping Type: Virtual Server
Incoming Interface: Wan1 (85.42.126.48)
Source IP: any
External IP: InterfaceIP_Wan1 (85.42.126.48)
Internal IP: Linux (192.168.1.49)
External Service Port: 9001
Internal Service Port: 22
Disable NAT Loopback
Policy Control
To: Lan1 (STATIC - 192.168.1.254)
Source: any
Destination: Linux (192.168.1.49)
Service: Linux SSH (TCP:22 UDP:22 PFSSH:9001)
User:any
Schedule: none
Action: Allow
After setting port forward i have try to access Linux with SSH from my home office and it is not working with a timeout error.
But It's okay to connect in the LAN env. [my workplace] using 85.42.126.48:9001
I also try to disable the [Security Policy Control] but it still not working.
BTW, i have try to change the NAT rules External Service Port: 22, as a result i can access from my home to workplace's Linux by using 85.42.126.48:22
Can anyone give a hand what I have setting error..?
  • Viols
    Viols Posts: 2
    I think I got the problem…my workplace's ISP have block a list of port…
    after I test with some ports, I finally get this answer…
    My settings are okay, but 9001 is not listening by my ISP…
