How do I disable Multicast-to-Unicast conversion on a Nebula AP?
- SSH to the Nebula managed AP
- Access the CLI of the Nebula managed AP
a. Check the wlan-radio-porifle name
Router# show running-config
wlan-radio-profile RADIO_SETTING_TYPE_5
activate
role ap
country-code TW
band 5G band-mode anacaxbe
5g-channel 36
ch-width 20/40
multicast-to-unicast
5g-multicast-speed 6.0
b. Enter the command:
Router# configure terminal
Router(config)# wlan-radio-profile RADIO_SETTING_TYPE_5
Router(config-wlan-radio RADIO_SETTING_TYPE_5)# no multicast-to-unicast
Then, type exit to apply the change.
Router(config)# write
c. exit configure terminal
d. Chek no multicast-to-unicast in wlan-radio-profile RADIO_SETTING_TYPE_5
activate
role ap
country-code TW
5g-channel 36
ch-width 20/40
Note: the “Multicast to Unicast Conversion” setting will be changed back to enabled if any configuration changes are made in the radio settings.
- 244 Nebula Ideas
- 6.9K Security
- 807 USG FLEX H Series
- 392 Security Ideas
- 88 Switch Ideas
- 60 Wireless Ideas
- 7.3K Consumer Product
- 333 Service & License
- 540 News and Release
- 106 Security Advisories
- 5.5K FAQ
- 89 About Community
- 124 Security Highlight
