Zyxel Switch DC Power Installation Guide
Zyxel_Judy
Zyxel_Judy Posts: 2,789
image  Zyxel Employee
edited August 4 in Other Topics
Precautions:
  • Ensure the DC PSU is disconnected before installation.
  • To reduce the risk of electric shock, properly ground the switch according to the User Guide (page 50 of XMG2230 series for example) before operation. If you cannot verify grounding, contact a certified electrician for assistance.
  • High-voltage DC PSUs and exposed power wires are dangerous. To ensure equipment safety and regulatory compliance, DC power connections must be performed by a certified electrician.
  • When connecting a DC PSU to the switch, ensure the positive and negative wires are correctly connected to the DC terminal block according to the DC connector on the rear panel.
1 Applicable Models and Power Budget
Model
DC input
Maximum DC power budget
Typical AC power budget
XMG2230-28HP
50-57 V
Up to 1440 W
Up to 700 W
XMG2230-52HP
50-57 V
Up to 2400 W
Up to 960 W
Note
If AC and DC power are connected at the same time, the system prioritizes AC input. For extended PoE budget, confirm that the switch is operating from DC input only.
2 AWG Wire Recommendation and PoE Budget Calculation
  • Zyxel recommends using 16–28 AWG DC wires to ensure stable power delivery.
  • The table below is a planning calculation based on 50 V DC and 10 A per 16 AWG positive/negative wire pair. It explains why additional wire pairs increase available DC-side power for PoE Budget.
Wire pairs
Calculation basis
PoE Budget (W)
1 pair of 16AWG
50V x 10A
500 W
2 pairs of 16AWG
50V x 20A
1000 W
3 pairs of 16AWG
50V x 30A
1500 W
4 pairs of 16AWG
50V x 40A
2000 W
5 pairs of 16AWG
50V x 50A
2500 W
6 pairs of 16AWG
50V x 60A
3000 W
Note
Use this table as a design estimate only. Actual usable power is limited by the PSU rating, switch DC input limit, switch PoE budget, cable length, voltage drop, temperature, terminal rating, overcurrent protection, and local electrical code.
3 DC Power Installation Workflow
Steps
Action
Acceptance criteria
Step 1
Verify PSU output
Check the back label or measure DC output toconfirm50-57VDCbeforeconnecting to the switch.
Step 2
Identify polarity and ground
Confirm or label +V, earth ground, and -V conductors clearly before insertion.
Step 3
Wire the terminal block
Before connecting six wire pairs to the DC terminal block, first verify the terminal orientation against the switch DC connector on rear panel to avoid reversing polarity.
Strip and keep approximately 1 cm of insulation from the wire ends to minimize exposed copper when connecting to the DC terminal block.
Step 4
Attach the DC connector
Insert the terminal block into the switch DC input and lift the side levers.
Step 5
Power on and observe
Turn on the DC PSU and monitor switch boot and PSU status.
Step 3 Detail
The 14-pin DC terminal block and Switch DC connector have six positive conductors and six negative conductors.
Caution
1.Do not connect any wires to the center 2-pin of the DC terminal block.
2.For grounding purpose, connect the grounding cable to the grounding screw on the rear panel of the switch.
Step4 Detail
Before inserting the DC terminal block into the Switch DC connector, lift the levers on both sides.
4 Deployment Scenarios
The following examples show how one external DC PSU can supply either a single high-power switch or multiple switches.
Note
It is necessary to reserve 60W for system operation on each switch. Allocating all DC power to Powered Devices (PDs) may overload the power supply, trigger protection mode and causing a shutdown.
Application Environment
  • Switches: one XMG2230-28HP and one XMG2230-52HP
  • 54V DC PSU, with a maximum output of 2500W
  • Six pairs of 16 AWG positive and negative wires
  • 14-pin D-sub terminal block (from switch brown box)
Scenario 1: Single XMG2230-52HP high-power deployment
Allocating a DC power source to a XMG2230-52HP.
Device
AWG Wire-pair
Configured Total Power
System Reserve
Planning budget
XMG2230-52HP
6 pairs
2400W
60W
2460W
Remaining power
40W
Scenario 2: One 2500W DC PSU shared by two switches
A single DC PSU can be shared across multiple XMG2230 switches. The allocation below keeps the combined PoE setting below the PSU rating after reserving system power for both switches.
Device
AWG Wire-pair
System reserve
Planning budget
XMG2230-52HP
4 pairs
1460 W
60W
1520W
XMG2230-28HP
2 pairs
900W
60W
960W
Total
6 pairs
2360W
120W
2480W
Remaining power
20 W
5 Web GUI Configuration
After the switch boots from the DC input, configure Total Power(W) via PORT > PoE Setup > PoE Setup. Click Apply and save the configuration. Then verify the value in PoE Status.
6 Recommended External DC PSU Models
Delta: PMS 2,500 W series / PMS-□V2K5W1BTD
Meanwell: UHP-1500 series
Meanwell: UHP-2500 Series
Zyxel_Judy
