Delete/modify ethernet interface, cause delete of DHCP static configuration on associated VLANs
Maverick87
Maverick87 Posts: 449
Zyxel Certified Network Administrator - WLAN Zyxel Certified Network Administrator - Nebula Zyxel Certified Network Administrator - Security Zyxel Certified Sales Associate
image  Master Member
edited August 26 in USG FLEX H Series
I've a following interfaces configuration:
If I remove or change somethings on IP on the LANIface, seems that also deleted all the entries into the DHCP Static configuration on the others Interfaces.
Probabily because the LANIface on port P3, interest also the VLAN on the same port.
In this specified case, if I modify the IP configuration on the LANIface, all the static DHCP entry are deleted for all the other interfaces (DomoDevices, MGMTIface, WLANGuests and WLANIface).
Can you verity this strange behaviou?
Thank you
    PeterUK Posts: 4,740
    image  Guru Member
    edited August 26
    Might be a specific way to cause this but I'm not seeing it.
    If I have
    ge12 LAN2
    192.168.168.1/24 (Static)
    Ethernet p12
    with a DHCP entry
    ge12 192.168.168.4 test-PC MAC Reserved
    then
    VLAN47 VLAN47
    192.168.255.43/28 (Static)
    47 VLAN p12
    with a DHCP entry
    VLAN47 192.168.255.44 testPC MAC Reserved
    If I edit like DHCP Pool Size either ge12 or VLAN47 that are both on P12 both DHCP entry stay or if I change ge12 LAN2 IP from 192.168.168.1/24 to 192.168.16.1/24 I get a note saying the Reserved will be removed for ge12 LAN2 but I still keep my DHCP entry for VLAN47
  • Maverick87
    image  Master Member
    Hi Peter,
    I don't receive any note but seems that is connected to the same port. For example:
    Now I don't have the bridge between LANIface and LANIface_2.
    To create a bridge between them, I need:
    • Unassociate the IP on both interface;
    • Disable the DHCP Server on both interface;
    • Create a new bridge interface between both, named differently but with a IP subnet/pool 192.168.1.1/24 (the old LANIface pool)
    Then I revert back all the configuration, so:
    • Delete the bridge
    • Reconfigure an IP subnet for LANIface_P2 (192.168.2.1/28 DHCP enabled)
    • Reconfigure an IP subnet for LANIface (192.168.1.1/24 DHCP enabled)
    This seems that these operations cause the lost of all reserved DHCP for all the interfaces
    image  Guru Member
    Do I simple setup step by step that cause the lost of all reserved DHCP for all the interfaces this will help Zyxel track the problem down.
  • Maverick87
    image  Master Member
    Thank you Peter
  • Zyxel_Tina
    Zyxel_Tina Posts: 1,014
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Switch 250 Answers 500 Comments
    image  Zyxel Employee
    Hi @Maverick87,
    Thank you for the information! We would like to ask for a bit more clarification. When you mentioned that “these operations cause the loss of all reserved DHCP entries for all the interfaces,” could you please confirm precisely which interfaces were affected?
    Specifically, does this refer to:
    • Reconfiguring the IP subnet for LANIface_P2 (192.168.2.1/28, DHCP enabled)
    • Reconfiguring the IP subnet for LANIface (192.168.1.1/24, DHCP enabled)
    Please feel free to share the complete procedure and results or screenshots with us so we can better understand the situation. Thank you.
    Zyxel Tina
  • Maverick87
    image  Master Member
    edited August 28
    Hi @Zyxel_Tina,
    seems that the problem occurs when you reconfigure an interface in with a port shares also VLANs.
    Obviously, when you delete the 192.168.1.1/24 interface, you lost every DHCP reserved. So, first you need to backup the DHCP list for the specified interface, then you need to reapply all the DHCP reserved uploading the DHCP Table file
