ZYXEL VMG8623-T50B PROBLEM WITH LOGIN TO ROUTER- LOCKED OR WRONG PASSWORD ,SOLVED!!!
maciejsiwnski87
in Home Router
SOLVED!
For anyone having the same login problem with the Zyxel VMG8623-T50B, after a factory reset the password printed next to “Login Password” on the label did not work for me.
The solution was:
Username: adminPassword: Enter the Serial Number (S/N) from the router label instead of the Login Password.
After entering the serial number as the password, I was able to access the router settings.
Hopefully this saves someone else some time.
- 243 Nebula Ideas
- 6.8K Security
- 783 USG FLEX H Series
- 389 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 325 Service & License
- 527 News and Release
- 101 Security Advisories
- 5.3K FAQ
- 91 About Community
- 122 Security Highlight
