What is the fan connector pin layout on the XS1930-12HP for fan replacement?
Zyxel_Judy
Zyxel_Judy Posts: 2,789
image  Zyxel Employee
The pin order for the fan connector is:
  • PIN1: Red = +12V
  • PIN2: Yellow = Sensor
  • PIN3: Black = GND
Please also note:
  • A fan that meets our design specifications will run at low speed when the device is powered on, and will increase speed as the device's internal temperature rises. Some non-spec fans may not start running immediately at power-on and only begin spinning once the device has warmed up.
  • Fans that are customer-selected or modified are not covered under warranty.
Zyxel_Judy
