Need AX7501-B0 Firmware
hey
would anyone be so kind and share the firmware for the AX7501-B0
( i need the 256KB version )
V5.17(ABPC.x)C0 (Revision B1 / 256KB block size)
if anyone would share it with me i would be thankful
i get this error when i flash the version i found on the init7 website
ERROR: NAND flash block size 256KB does not work with an image built with 128KB block size
bcmNandImageSet failed, rc=-1
hi aggain people
after a few days of reverse engineering and testing stuff i have finally been able to
extract the files from the .bin
repack them as 256kb
modify some bytes of the file to pass the checks that blocked the flash
i was at my last attempt i was ready to accept my loss but then it started flashing
after a while it restarted
Now i have access to the CFE terminal (no more password)
but also i believe it flashed the firmware
currently it is bootlooping i assume i uploaded the wrong firmware or that i broke somthing somwhere
but i will keep researching until i manage to flash a working version of an unlocked firmware
i saw the im not the only one who had that problem on this forum so i will post all my research and everything i found once i get this to work propperly0
- 241 Nebula Ideas
- 6.8K Security
- 759 USG FLEX H Series
- 380 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 321 Service & License
- 520 News and Release
- 100 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
