Wifi Extender for outdoor use
Hi @jef
Since NWA55AXE can't be controlled by USG FLEX 700, you might need to setup the mesh setting on NWA55AXE manually.
For WAX630s, please check root AP part:
For NWA55AXE, please check repeater part:
Zyxel Melen0
Yes you that should be possible I have a similar setup with USG60W as controller to a WAX510D then standalone NWA50AX PRO
Hi @jef
Zyxel Melen0 -
Thanks, I believe I will purchase the NWA55AXE and give it a try.
Quick follow up question: In the "AP group" in the "profile" on each radio in that profile, I need to change from "AP Mode" to "Root AP" and that should not effect my existing wifi setup?
AP Mode v Root AP anything important about that change I should be aware of?0 -
Hi @jef
No, it won't effect the existing wifi. Change mode allows your root AP to broadcast the mesh SSID out. In AP mode, the AP won't broadcast the mesh SSID.
Zyxel Melen0
- 244 Nebula Ideas
- 6.9K Security
- 807 USG FLEX H Series
- 392 Security Ideas
- 88 Switch Ideas
- 60 Wireless Ideas
- 7.3K Consumer Product
- 333 Service & License
- 541 News and Release
- 106 Security Advisories
- 5.5K FAQ
- 89 About Community
- 124 Security Highlight
