reset interface via script not working
I use script to reset interface :
first :
configure terminal
interface O2_VDSL
shutdown
second :
configure terminal
interface O2_VDSL
no shutdown
schedule every night 2:00 and 2:01 in terminall
When I use fw 4.33 evething is OK ( interface go down and up ) Now I using fw 4.35 and when script run - interface is down ( in web is grey ) but still working ( I ping on it !!! ) In log I don´t see interface is down.
Zdenek B
Hi @ZdenekB,
Here is the test result for your reference.
Model: USG210
Firmware: 4.35(AAPI.0)
Two scripts:
Commands:
Router(config)# schedule-run 1 shutdown_lan1.zysh daily 16:50
Router(config)# schedule-run 2 enable_lan1.zysh daily 16:58
Router(config)# write
Result:
The interface lan1 is disabled and enabled on schedule.
5
Hi @ZdenekB,
Model: USG210
Two scripts:
Commands:
Result:
5
- 242 Nebula Ideas
- 6.8K Security
- 764 USG FLEX H Series
- 385 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 323 Service & License
- 522 News and Release
- 100 Security Advisories
- 5.3K FAQ
- 91 About Community
- 121 Security Highlight
