Slow upload speed on ZyWALL 310
Hi @vladimire
Is there any device connect between modem or client?
Can you direct connect ZyWALL310 between modem and PC to check SpeedTest again?
And make sure interface connection has auto-negotiated as1000M/Full. And also test it by different PCs.
Stanley, thank you for taking the time to reply. Other than a patch panel, there is nothing between the modem and the router. When I was testing from my PC directly, I was plugging into the same port of the same patch panel, so wiring is not an issue. All my connections are auto-negotiated and at 1000M/full.
Port 1 is my main WAN (gigabit fiber), port 2 is a secondary WAN that is set up as failover, ports 3 and 8 are local LANs. The failover is set up using a custom trunk:
As my experience, you should try to let PC connect with Zywall device directly without patch panel to narrow down issue, since UTM, BWM all disable.0
Thank you, Jeremy, but this is not possible in my case, I have over 50 desktops on my network.
@vladimire
Regarding to this case,
we suspect that it could be some kind of connectivity issue between Zwall310 and Patch Panel.
Since from our test result, the upload throughput can be go up more than 500 Mbps.
Therefore, we need your help to check what if you use the PC to connect with Zywall 310 directly.
- 243 Nebula Ideas
- 6.9K Security
- 793 USG FLEX H Series
- 391 Security Ideas
- 88 Switch Ideas
- 59 Wireless Ideas
- 7.3K Consumer Product
- 327 Service & License
- 530 News and Release
- 104 Security Advisories
- 5.4K FAQ
- 91 About Community
- 122 Security Highlight
