Wifi 6 APs connecting
halprewitt
halprewitt Posts: 1 image  Freshman Member
edited May 2024 in Wireless
Discovered on the WAX650S must have QoS on (WMM) else Wifi6 11ax will not work. Stations (users) fail to connect using the 11ax mode.
  • Zyxel_Freda
    Zyxel_Freda Posts: 397
    25 Answers First Comment Friend Collector Third Anniversary
    image  Zyxel Employee
    Hi @halprewitt ,
    It's mandatory to have QoS after 802.11n, so does 802.11ax. So, when you disable the WMM, it would not use 802.11ax mode. May I know that do you have any concern to use it?
