Several Site-to-site with Dynamic Peer IKE1 connection -- wrong Phase2 for Phase1
Hello, USG40, I have two Site-to-site with Dynamic Peer IKE1, with different algos, with different shared key and with different remote-policy / phase2 settings. Connection 1 is established and working, but when I try to establish connectinon 2, from the log I see that Phase 1 (in VPN Gateway in Web GUI terms) identifies the peer, but, then it tries to build Phase2 (VPN Connection) according Connection 1 settings.
I clearly bind Phase 2 settings to Connection 2 and see it as remote-policy in config (I configure things via WEB and check via cli)
The alike configuration with two IKE2 site-to-site-with-dynamic-peers works without problem.
What to do? The remote devices with IKE1 cannot do IKE2.
Hi @Dreadbit
You may try to configure different “Local ID” in phase 1.
It can help system to select in correct VPN rule when there are many dynamic rules.
@Zyxel_Stanley , thanks for reply.That did not help. I set a unique Local ID type on server/incoming side and also changed Peer ID to unique (and it matches with the caller).As before -- phase I is ok, and phase II is selected the wrong way.0
Hi @Dreadbit
Can you post your VPN setting or send your config to me by private message for further check?
Zyxel_Stanley thanks for your help, dropped you a private message.
Hi, did you get any further with that investigation? We have been observing similar behaviour in the past, too. But it's hard to analyse with ~20 active IPSec VPN's.
- 244 Nebula Ideas
- 6.9K Security
- 808 USG FLEX H Series
- 392 Security Ideas
- 88 Switch Ideas
- 60 Wireless Ideas
- 7.3K Consumer Product
- 333 Service & License
- 541 News and Release
- 106 Security Advisories
- 5.5K FAQ
- 89 About Community
- 124 Security Highlight
