Multy U AC2100 problems, node restarts on high load and another node stopped working correctly
Oystein Hermansen
Multi U Wifi Mesh from Zyxel. 3 nodes, firmware V1.00(ABMY11)CO (latest version).
Main unit running in BRIDGE MODE. Node 2 and 3 connected to main unit using wireless only.
System was first installed in October 2020 with two SSIDs (one for 2.4 and one for 5 Ghz) and has been running without any problems since then. But in December (week 51/52) I got problems.
Node 3 starting acting strange. Used Wifi-scanner and found that it had stopped broadcasting the SSID for 5 Ghz. Tried to restart all units. Did not correct the problem. Wifi scanner found all 3 three back-bone channels open (Main - Node 2, Main - Node 3, Node 2 to Node 3). But Node 3 refused to broadcast SSID for 5 Ghz, only the SSID for 2.4 Ghz.
Removed Node 3 using the app on my iPhone and powered it off. Restarted the whole system (Main unit and Node 2). A Wifi-scan shows the back-bone channel on 5 Ghz and 2 SSIDs available (2.4 and 5 Ghz) from each node (Main and Node 2). System seems to work ok, but I have experienced an unplanned reboot of Node 2 two times. My AppleTV and smart-TV is connected to Node 2 using Ethernet through a switch (historic reasons). Node 2 functions as both a wired-wireless gateway (which it supports and have done without problems for 2 months) and as a mesh unit broadcasting SSIDs for 2.4 and 5 Ghz.
There are currently between 15 and 20 active (from time to time) wifi clients using the SSIDs.
By using Wifi-scanner, I see that the Wifi network is not overcrowded and should provide no problems.
Problem as I see it:
1) Why did Node 3 stopped working like it should and not broadcasting and allowing connections over 5 Ghz?
2) If I sit approx 3 meter (in my living room) my laptop is connected to Node 2. Starting a Speedtest from (speedtest.net) will force a reboot of Node 2 approx 30% (⅓) of the times. I am connected to a 100 mbps Internet using fiber.
If I do the same speedtests using the Speedtest app from my AppleTV connected to Node 2, it never reboots. I get a 95/95 mbps from my AppleTV. From my laptop (Apple Macbook Pro) I get the same results (95/95 mbps) if Node 2 doesn´t reboot. Such reboots of Node 2 have also happend if there are many clients connected to Node 2 and they create much traffic (TCP/UDP traffic).
Any advice?
Any advice?
Dear Sir,
We have received your feedback from Multy App, and we will contact you via email.
Best regards,
Jerry0
- 237 Nebula Ideas
- 6.8K Security
- 740 USG FLEX H Series
- 376 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 91 About Community
- 119 Security Highlight
