how to properly setup a vpn using usg20-vpn for home users with same ip scheme?
I have a company that has a USG20-VPN, and they want to set up a VPN which i did using remote access (server role), the issue is they using 192.168.1.1/24 subnet and some of the home users has the same subnet as well, so they cant connect to for example RDP, wondering what is the proper way to set this up, guides that i looked, they all made for site to site configuration, which i tried but not success. any help is appreciated. thanks
With the VPN in server role you can change in L2TP vpn for the IP address pool to like 192.168.255.0/24
Also the USG20-VPN LAN should not use 192.168.1.1/24
hello, using the quicksetup i am able to create the vpn with no problem so it works as long the client is not in the same subnet (192.168.1.1/24), do i need to enable IPSec NAT on Inbound Traffic Destination NAT. ?
also followed this video guide , with no success. thanks0 -
Clients can use 192.168.1.1/24 if the USG LAN is not using 192.168.1.1/24 and the VPN is not using 192.168.1.1/24
If the USG LAN and VPN is using 192.168.1.1/24 the Clients must not use 192.168.1.1/24
You don't need to use IPSec NAT on Inbound Traffic Destination NAT you do need a firewall rule to allow VPN zone (IPSec_VPN) to LAN1
is there any step by step in how to do this? i tried all possible ways and still cant get it to work0
In my setup the USG LAN1 is 192.168.255.0/24
In VPN > IPSec VPN tab VPN Gateway change interface to WAN1
In VPN > IPSec VPN tab VPN connection
In VPN > IPSec VPN tab L2TP VPN change DNS and allowed user as needed.
When a client with 192.168.1.2 connects to the VPN gets 192.168.140.1 and needs to RDP to 192.168.255.250 you make a firewall rule to allow VPN zone (IPSec_VPN) to LAN1.
Also for the VPN connection you need firewall rules:
from IPSec_VPN to ZyWALL service VPN_IPSEC group with ESP, IKE, L2TP-UDP and NATT
from OPT or WAN1 to ZyWALL service VPN_IPSEC group
- 237 Nebula Ideas
- 6.8K Security
- 740 USG FLEX H Series
- 377 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 91 About Community
- 119 Security Highlight
