LTE4506-M606 Wi-Fi LED status
FreemanJJ
FreemanJJ Posts: 45
Fourth Anniversary
image  Freshman Member
edited November 2017 in Smart Home Product
I found the Wi-Fi LED display when turn on WPS function and data transmit the flashing speed is same. the speed are no any different for slow or fast.
#LTE_November
  • YeK
    YeK Posts: 150
    image  Master Member
    Hi FreemanJJ,
    For my LTE4506, the flashing speed when enable WPS is slower than transmit data. You might  disable/enable WPS to check again.
  • FreemanJJ
    FreemanJJ Posts: 45
    Fourth Anniversary
    I try many times WPS dis/enable and compare with transmit data there are no any different speed of light.
