Mount usb after reset.
vulturu39
vulturu39 Posts: 1 image  Freshman Member
edited June 2018 in Home Router
I have a ZyXel NBG5615 router. If I reset the router, the hard disk on UBS1 is not automatically mounted. Removing the plug is required. Access to port 21 address 192.168.1.1 from WAN works only for other addresses.
#Router_June
  • Penny
    Penny Posts: 65 image  Ally Member
    edited June 2018
    What do you mean about "Access to port 21 address 192.168.1.1 from WAN works only for other addresses."? If you want to access NBG5615 from outside, you need use WAN IP (public IP) to access it. (192.168.1.1 is private IP.)
