Video broadcasting problem
We have a WAC6502D-S for e-learning system.
Problem appears when broadcasting the videos from teacher laptop to student’s pad. The videos would be from sources: local harddisk, youtube, cloud server
- VCD/SD video resolution ==> smooth transfer without delay and good buffering/ playing but the video quality is not good due to the low resolution.
- HD 720 x 1280 resolution ==> interrupted transfer/ buffer; broken video play
Does anyone have idea or suggestion for this case?
Hi @Hedy,
If you use 2.4GHz radio, you can refer this FAQ to adjust the performance.
https://businessforum.zyxel.com/discussion/470/how-to-optimize-wireless-performance-on-2-4-ghz#latest
If you use 5GHz radio, maybe you can use 40MHz for bandwidth if there is not other co-channel use.
For the HD vedio, I suggest you adjust the multicast rate through the AP’s web GUI from 1Mbps to 11Mbps, 18Mbps, 24Mbps, and so on. The multicast rate must higher than your video traffic.
Kathy1 -
Hi Kathy,
Thanks for your suggestion. There are 2.4G and 5G in my environment at the same time. I tried to adjust the value as you suggested. After testing, the video quality is better than before. I should make a record for this topic for further usage.
Thanks.
- 236 Nebula Ideas
- 6.8K Security
- 739 USG FLEX H Series
- 376 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 91 About Community
- 119 Security Highlight
