USG40: My PC on LAN1 cannot connect to a device on LAN2
ZyXEL Device: USG40.
I have a ALLWORX 6 VOIP switch on LAN2, IP 172.16.10.254\24, Interface 4. My PC is on LAN1, IP 192.168.10.73\24, Interface 1. I am trying to connect to the ALLWORX's web configuration server, unsuccessfully, so for. I have plugged my PC directly into the ALLWORX and it provided my PC with an IP and I was able to connect successfully, so it will accept connections. I'd like to be able to get to the ALLWORX through the network for convenience and so I can work on its configuration from my iPAD or another device.
There is a direct route configured, that I believe was established when I created the 172 network on LAN2. See the Following image please.
I have not established a Policy Route yet, as I didn’t think I’d need it.
What I know so far.
I can successfully ping the USG40's interface on LAN2 at 172.16.10.1 FROM MY PC.
I cannot ping the ALLWORX FROM MY PC.
What I know so far.
C:\>ping 172.16.10.1
Pinging 172.16.10.1 with 32 bytes of data:
Reply from 172.16.10.1: bytes=32 time<1ms TTL=64
Ping statistics for 172.16.10.1:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 0ms, Maximum = 0ms, Average = 0ms
C:\>ping 172.16.10.254
Pinging 172.16.10.254 with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 172.16.10.254:
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
The USG40 can successfully PING the ALLWORX using the built in Diagnostic tools.
I think I need a policy route, but I've played with that all night with no success.
Any help would be provided.
Thanks.
JE.
#Biz_Security_Jan_2019
# ping 192.168.10.254 -n -c 3
PING 192.168.10.254 (192.168.10.254) 56(84) bytes of data.
64 bytes from 192.168.10.254: icmp_seq=1 ttl=64 time=0.291 ms
64 bytes from 192.168.10.254: icmp_seq=2 ttl=64 time=0.186 ms
64 bytes from 192.168.10.254: icmp_seq=3 ttl=64 time=0.160 ms
--- 192.168.10.254 ping statistics ---
3 packets transmitted, 3 received, 0% packet loss, time 1998ms
rtt min/avg/max/mdev = 0.160/0.212/0.291/0.057 ms
Thanks.
JE.
Did you enabled the layer 2 isolation function or proxy-ARP on the device? If so, you can try to turn it off and see if it works0
- 244 Nebula Ideas
- 6.9K Security
- 801 USG FLEX H Series
- 392 Security Ideas
- 88 Switch Ideas
- 59 Wireless Ideas
- 7.3K Consumer Product
- 329 Service & License
- 532 News and Release
- 104 Security Advisories
- 5.5K FAQ
- 91 About Community
- 124 Security Highlight
