Problem with adding a IPv4 static route
Jktz85
Jktz85 Posts: 1 image  Freshman Member
edited April 2020 in Smart Home Product
Hi there,
I'm running into a weird problem with adding a simple IPv4 static route.
My Zyxel is connected VPN site-to-site to another network B. In network B there is another network C with IP range 192.168.0.0/24.
Now I want to be able to reach 192.168.0.0/24 from my Zyxel.
I tried adding a static route with destination ip 192.168.0.0 subnet mask 255.255.255.0 gateway ip 192.168.1.2(vpn router on network B ).
I always get the following error message:
CLI Number: 0
Warning Number: 48000
Warning Message: 'Static route adding failed'
It still shows up on the table but doesn't work. When I try to ping it gets redirected to my WAN interface.
Any suggestions?
  • Jeremylin
    Jeremylin Posts: 166 image  Master Member
    First Answer First Comment Third Anniversary
    edited April 2020
    Need to add policy route on both sides.
    EX: On site A, Source:Local Subnet(A,192.168.0.0/24), Destination: Remote Subnet(B), Next Hop: VPN tunnel, Select the name of VPN rule
    On site B, Source:Local Subnet(B), Destination: Remote Subnet(A,192.168.0.0/24), Next Hop: VPN tunnel, Select the name of VPN rule
