The GS1900-24HP can power ubiquiti access point and other stuff (802.3af/A PoE)?
uiblog.it
uiblog.it Posts: 1 image  Freshman Member
edited August 2022 in Switch
hello everyone, I would like to know if the switch in question (GS1900-24HP-EU0101F) is able to power the following ubiquiti products via PoE:
UAP-AC-M (802.3af/A)
UAP-AC-LITE (802.3af/A)
Ubiquiti Unifi Controller, Cloud Key (Power Method: PoE 48V 802.3af or Passive PoE (Pairs 4, 5+; 7, 8 Return) or Micro-USB 5V
Power Supply: 802.3af PoE or Micro-USB 5V, Minimum 1A
Max. Power Consumption: 5W)
Thanks for a possible reply.
#Biz_July_2020
  • Zyxel_Derrick
    Zyxel_Derrick Posts: 126 image  Zyxel Employee
    edited July 2020
    Hi @uiblog.it
    GS1900-24HP follows the PoE standard which can support 802.3at/af and uses wire 1.2.3.6.
    Therefore, if these two products also follow the standard and use wire 1.2.3.6 then it can be powered up by our switch.
    You can check the further detail on GS1900 series datasheet
    https://www.zyxel.com/support/download_landing/product/gs1900_series_9.shtml?c=gb&l=en&pid=20130521174809&tab=Datasheet&pname=GS1900%20Series
    Friendly remind that this forum is for home devices, for our business model devices such as GS1900 series, you may seek our biz forum. https://businessforum.zyxel.com/
    Thanks!
    Best regards,
    Zyxel_Derrick
  • TiggerLAS
    TiggerLAS Posts: 67 image  Ally Member
    First Comment First Answer Fifth Anniversary
    I can confirm that the GS1900-24HP can successfully power a compatible UniFi access point.
    We've been using a GS1900-24HP at our office for over a year now,
    in combination with a UniFi UAP-AC-LR access point, and it works just fine.
    Be careful though - some of the older UniFi access points, such as the
    Unifi UAP, and UAP-LR access points use passive POE, and won't work
    without a power injector.
    As long as your devices use either 802.3af or 802.3at, you should be good to go.
