Using a wildcard SSL certificate for Zywall 1100's web interface
OneZyUser
OneZyUser Posts: 10
image  Freshman Member
edited April 2021 in Security
Hi all,
 Is there a way to import an already-generated wildcard certificate into Zywall 1100 to serve as the SSL cert for its https interface? Everytime I try to import the cert, I get a response that the original CSR is not present. It was actually generated on a different machine and hence unavailable here.
Any clues on how to get it working?
  • OneZyUser
    OneZyUser Posts: 10
    Thanks @zyman2008 I did that, but right after I did it, the web interface became unavailable until I reverted back to the old (URL specific certificate).
    Is there any thing else that is needed when the certificate has is wildcard?
  • OneZyUser
    OneZyUser Posts: 10
    Nevermind my last reply...
    The first time, I generated a pkcs12 file with both the cert and CAcert bundled together.
    After some thought, I imported the CA cert separately (the direct crt file I got from namecheap) and generated a pkcs12 with only the wild card crt file. This did the trick.
    Thanks again to @zyman2008 for the advice.
