ZyXEL Dual-Band Wireless N450 with Virgin hub3
ygor
I have a question about an old wireless adapter I use since 2014. It always worked flawlessly with the Virgin Hub 2, getting the same speed as the ethernet cable that is about 110 mps. Now that I have upgraded to the Hub 3 router I can't get past 76 mps altough on my phone I can still reach 110 mps.
Anyone knows why?
Anyone knows why?
Hello @ygor
From looking at https://www.broadbandchoices.co.uk/guides/hardware/virgin-media-broadband-routers I can see that Hub 3 is dual band.
Do you know if your N450 is trying to use 5GHz wifi?
If it is, then do you get better performance if you switch to use the 2.4GHz band?
I hope that this is helpful.
Merry Christmas and Happy New Year.
Tony0 -
Hello @ygor
Are you using the 2014 software versions available at https://www.zyxel.com/support/SupportLandingSR.shtml?c=gb&l=en&kbid=M-01488&md=NWD2705 ?
Tony0
- 243 Nebula Ideas
- 6.8K Security
- 781 USG FLEX H Series
- 387 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 324 Service & License
- 527 News and Release
- 101 Security Advisories
- 5.3K FAQ
- 91 About Community
- 121 Security Highlight
