Extended dchp option
Which is the "DHCP Option" Number you have to create?
For instance the TFTP Server name is Option 66 or 150
161 and 1620
My bad...
I did not remember than USG300 is a ZLD 3.x device, not a ZLD4.x device. Therefore, as far as i can remember, the options of DHCP Server cannot be created, at least via GUI (Web Interface).
Considering age and lack of support (latest firmware dated 2015), if you need the service, you should:- use another DHCP Server not from USG device
- change your USG device to a newer one, USG or VPN due to your necessity (210 or 310 model)
ftp://ftp.zyxel.com/ZyWALL_USG_300/cli_reference_guide/ZyWALL USG 300_7.pdf
Seems present a CLI Command for add options to DHCP.6.2.2.2 DHCP Extended Option Setting Command Example
Assuming DHCP_TEST as the name of the DHCP poolRouter(config-ip-dhcp-pool)# exit<br>
Router# configure terminal<br>Router(config)# ip dhcp pool DHCP_TEST<br>Router(config-ip-dhcp-pool)# dhcp-option 120 sip ip 192.168.1.20<br>
I dont know the correct syntax for the option 161...
Yes they can be created through gui. There is the show advanced option in the vlan. Unfortunately the string is not in the list. Is there any alternative that I can use to string?
Great thanks.1
- 431 Beta Program
- 2.6K Nebula
- 165 Nebula Ideas
- 6K Security
- 364 USG FLEX H Series
- 292 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 262 Service & License
- 407 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
