4G Dongle on USG60W
Good morning,
I bought a Huawei E3272 4g dongle inserted in the USB port of the firewall. The dongle seems working correctly but when i disconnect the wan for testing, the connection fail after 10 seconds. Seems it not work properly, also if the USG60W recognize it.
Thanks in advance,
best regards
Alberto
Thanks in advance,
best regards
Alberto
Best Answers
5
Hi Alberto,No access to the device now but they probably call it mms. If I remember well it's set to AUTO now, change it to MANUAL and change value from 1492 to 1200.Cheers,M5
Hi Alberto,On ours its changeable without recreating. Goto Network->Interface->Cellular then Edit Cellular1Click 'Show Advanced Settings' then under Interface Parameters->Advanced there's MTU.Anyway good to hear it's working.Cheers,M5
@Alberto
Regarding to your description,
if the connection failover to another interface, the session will be interrupted for secs and than will up immediately.
As I checked this case with Huawei E3272 internally, when the active interface is disconnected, the backup interface will bring up and takeover in one sec.
Can I know what is your test steps for this case?
Charlie
Hi Charlie, thanks for your reply.I did some tests, one was connect the dongle to the USG60w and create a rule for my pc to use that interface for navigation but, when i tried a speedtest, I lost the connection after 2 seconds.I thought i made a mistake in previous configuration so i followed this guide: https://kb.zyxel.com/KB/searchArticle!gwsViewDetail.action?articleOid=015539&lang=EN and tried to put both wan1 and wan2 in inactive state (grey bulb). Also in this test, the connection seems working just for a second.
I tried again today and seen in the interface monitor that the dongle is connected until there is traffic. As soon as I try a speedtest, the status became red and the message is "disconnected"0 -
5
Hi All,Is there any news on this? we got the same issue with an USG60W and a Huawei E303Cellular connection is up but the dataflow stops when opening a webpage. Disconnecting -> Connecting restores it until refreshing the webpage.Edit: changing the MTU size does seem to have some effect, need to further investigate.Thanks,M0
Solution for me was to change the mtu size of the cellular interface to 12000
Hi Haplo,I contacted Zyxel Italy and they did some test on my firewall. After these tests they reported me that for them there wasn't any problems or malfunction. I tried again some times but I still have the same exact problem that you reported.Tomorrow I'll update to the new firmware and I'll try your solution. ^_^b0
Hi Alberto,Curious if it works for you, in my test setup now all works. 2 WAN (cable + adsl) 1 Cellular. WAN load balanced, Cellular as fallback. All with active IPSec Dialup VPN to our datacenter. Looking forward taken this live with a few devices soon.Cheers,M0
Hi Haplo, i tried yesterday after installed the new firmware. Same results.
I created a routing for my pc for using cellular1, tried a speedtest by ookla but after 5 sec. of test, my connection dropped.
I didn't find where to change the MTU size for cellular10 -
Hi,i've found the option. The problem is that once you connect the dongle, the firewall automatically detects it and pre-configure it, no particular options to set (so i didn't find where to set the mtu size).You must create a new cellular connection and after the selection of the usb port, you can configure many more options (like the provider, mtu size, etc.). Once you confirmed the configuration, those options are not longer visible, like the previous auto-configuration made by the firewall. Don't know why the made this choice
Anyway, I set MTU size to 1200 like you suggested and it works perfectly.Thank you very much!!!
Ciao,
Alberto1
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
