[Alert] Network-Firewall-----AP Disconnect
Zyxel_Vic said:Hi @Tattoofreak
Sent in private message
I am having the same issue on USG20W-VPN firmware 4.33. Please share the patch! thanks
Hi @mizzomizzo
Here is the firmware download link,
ftp://ftp2.zyxel.com/USG20W-VPN/firmware/433ABAR0ITS-WK19-r88384.zip
thanks 😁
I have the same problem with a USG40W.
I see on the FTP two firmwares that look like the one you're talking about for the USG20VPN, here:
- ftp://ftp2.zyxel.com/USG40W/firmware/433AALB0ITS-WK12-r87753.zip
- ftp://ftp2.zyxel.com/USG40W/firmware/433AALB0ITS-WK19-r88384.zip
can I apply either to solve the problem, and wich one ?
(exactly the same problem: AP Disconnect. MAC:xx:xx:xx:xx:xx,Name:Local-AP,Reason:Idle in RUN State,Model:USG40W)
i've had the answer in private message, didn't saw.
i'm applying ftp://ftp2.zyxel.com/USG40W/firmware/433AALB0ITS-WK19-r88384.zip
i'll post result.
i m very perplexe that french support team know this problem for me since at least 4 years .... and the only answer was : reboot device, it's not intended to run 24/7 .....
Is this issue resolved with firmware 4.35? Can I upgrade without being concerned to fall into the samie issue again?0
@Zyxel_Cooldia Is this issue resolved with firmware 4.35? Can I upgrade without being concerned to fall into the samie issue again?
Hi @Tattoofreak,
The fix for Built-in access point (local AP) and internal AP disconnect issues are merged to 4.35.
Zyxel_Emily said:Hi @Tattoofreak,
- 435 Beta Program
- 176 Nebula Ideas
- 425 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 419 News and Release
- 89 Security Highlight
