This configuration can only be modified in Easy Mode
RiKa
RiKa Posts: 8 image  Freshman Member
First Comment Sixth Anniversary
edited April 2021 in Security
Today I did the update on the ZLD 4.35 on a USG60W. Since then, I can only make some settings such as changing Firwall rules via Easy Mode. That is not practical ... Is it possible to change this feature ???
    PeterUK Posts: 4,427 image  Guru Member
    If your in easy mode change to expert mode.
