Trouble go from 433AAAA0ITS-WK30-r89425 to V4.35
It even failed when going back to V4.33 so had to load the config with “Ignore errors and finish applying the configuration file” then load V4.35. Should anyone else have the same issue
So all working including my USG40/60 that upgraded fine.
Noticed the new source IP in NAT sure some will make use of that, was hoping for other added bits so waiting for them.
Hi @PeterUK,
In our lab, there is no problem upgrading ZyWALL110 from 433AAAA0ITS-WK30-r89425 to 4.35.
The firmware 4.35 is uploaded to the standby partition.
ZyWALL110 reboots successfully with the startup-config.conf.
Here is the whole process of firmware upgrading for your reference.
https://www.dropbox.com/s/9ilrrzl9u7opo1x/435.wmv?dl=0
If you still get problem with upgrading from 4.33WK30 to 4.35, please share the configuration file with us to check the symptom.
You might have had no problem but I did, something in the config it didn't like but like I said I loaded V4.33 which also didn't like my config till I loaded my config by “Ignore errors and finish applying the configuration file” then V4.35 loaded fine.
So all fine now
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
