ATP 200 SSL Inspection error
on my ATP 200 I activated SSL Inspection.
After updating to MAC OSX 10.15 Catalina I get this error:
NET::ERR_CERT_WEAK_KEY
I use the default certificate.
With the previous version 10.14 it worked fine.
Browser : Chrome and Safari , latest version.
Is the problem due to this?
https://www.macrumors.com/2019/06/06/apple-deprecates-sha1-macos-catalina-ios-13/
https://support.apple.com/en-us/HT210176
How to solve? Thanks
Regards
Hi @Ceccus
Welcome to the forum.
I suspect you are right.
So I recommend generating new certificates and upload them as the following KB explains:
https://kb.zyxel.com/KB/searchArticle!gwsViewDetail.action?articleOid=003075&lang=EN
I hope it helps.
Regards
Thanks for the reply.I think the problem is generalized and I also think that Zyxel should remedy by making a new certificate availableRegards0
Firmware upgrade ... i suppose.
Regards0 -
Hi @Ceccus,Thanks for reporting.It is confirmed as a bug.We are working on fixing it. I will send the firmware to you for verification after the bug is fixed.0
Thanks for the replyThank you so muchWaiting for the Fix
Regards0 -
Hi Emily,
How long will the Fix be available?
Regards
Hi @Ceccus,
We modify the format of entries in the certificate to satisfy the requirements of MacOS 10.15 and it is still under verification.
I will update the test results in the near future.
Hi @Ceccus,
The firmware is sent to you in the private message.
problem still open ... firmware slow in SSL Inspection.
Any ideas ?
- 440 Beta Program
- 292 Service & License
- 4.6K FAQ
