Site to Site VPN to Meraki endpoint
Hi All, very new to all of this but I'm trying to get a site to site vpn setup between our Zywall 310 and a Meraki box, I've got the pre-shared keys the same and I think the config setup right but it's not coming up. Has anyone done this or can point me in the direction of some instructions on what to do ?
Hello cre8toruk,
G'day
There is the guideline can help you double confirm the configuration on USG series.
FAQ link:
https://businessforum.zyxel.com/discussion/551/an-example-of-site-to-site-vpn#latest
Secondly,
if the issue still appear, please share the "IKE" log message to us for checking.
Go to Monitor>Log>View Log>Select IKE on the category
Charlie0 -
I have this working, but it's specifically necessary to configure the Ubquiti (eg: EdgeRouter Lite) via the command-line.From my notes on this. Assumes you already have access via ssh, although it's possible to use the "command" box via a browser, I recommend against using that.Please double-check and verify, and the settings used need to match the configuration for your Zyxel USG.Here is their guide which you should read in full:IMPORTANT: Verify the port (name) of your Ubiquiti's WAN port and alter where I have "eth1" if needed. Also, this example has the Ubiquiti LAN as 192.168.10.0 and the Zyxel LAN as 10.0.0./24 - obviously adjust each accordingly.
set vpn ipsec esp-group FOOset vpn ipsec esp-group FOO compression disableset vpn ipsec esp-group FOO lifetime 28800set vpn ipsec esp-group FOO mode tunnelset vpn ipsec esp-group FOO pfs enableset vpn ipsec esp-group FOO proposal 1set vpn ipsec esp-group FOO pfs dh-group2set vpn ipsec esp-group FOO proposal 1 encryption aes256set vpn ipsec esp-group FOO proposal 1 hash sha1set vpn ipsec ike-group FOOset vpn ipsec ike-group FOO lifetime 28800set vpn ipsec ike-group FOO proposal 1set vpn ipsec ike-group FOO proposal 1 dh-group 2set vpn ipsec ike-group FOO proposal 1 encryption aes256set vpn ipsec ike-group FOO proposal 1 hash sha1set vpn ipsec ipsec-interfaces interface eth1set vpn ipsec logging log-modes allset vpn ipsec logging log-modes controlset vpn ipsec nat-traversal enableset vpn ipsec site-to-site peer xx.staticWAN-IP.ofYour.Xyxel set vpn ipsec site-to-site peer xx.staticWAN-IP.ofYour.Xyxel local-ip XX.WANIP.OFYOUR.UBIQUITIset vpn ipsec site-to-site peer xx.staticWAN-IP.ofYour.Xyxel authentication mode pre-shared-secretset vpn ipsec site-to-site peer xx.staticWAN-IP.ofYour.Xyxel authentication pre-shared-secret longSecretPasswordHereset vpn ipsec site-to-site peer xx.staticWAN-IP.ofYour.Xyxel connection-type initiateset vpn ipsec site-to-site peer xx.staticWAN-IP.ofYour.Xyxel default-esp-group FOOset vpn ipsec site-to-site peer xx.staticWAN-IP.ofYour.Xyxel ike-group FOOset vpn ipsec site-to-site peer xx.staticWAN-IP.ofYour.Xyxel tunnel 1set vpn ipsec site-to-site peer xx.staticWAN-IP.ofYour.Xyxel tunnel 1 allow-nat-networks enableset vpn ipsec nat-traversal enableset vpn ipsec nat-networks allowed-network 0.0.0.0/0set vpn ipsec nat-networks allowed-network 10.0.0.0/24set vpn ipsec site-to-site peer xx.staticWAN-IP.ofYour.Xyxel tunnel 1 allow-nat-networks disableset vpn ipsec site-to-site peer xx.staticWAN-IP.ofYour.Xyxel tunnel 1 allow-public-networks disableset vpn ipsec site-to-site peer xx.staticWAN-IP.ofYour.Xyxel tunnel 1 esp-group FOOset vpn ipsec site-to-site peer xx.staticWAN-IP.ofYour.Xyxel tunnel 1 local subnet 192.168.10.0/24(THIS IS THE LAN OF THE Ubuiti ER)set vpn ipsec site-to-site peer xx.staticWAN-IP.ofYour.Xyxel tunnel 1 remote subnet 10.0.0.0/24 (THIS IS THE LAN OF THE Zyxel)commitsaveexit0 -
Note: Copy and paste into something else, this forum software is line-wrapping where there shouldn't be newlines.0
- 440 Beta Program
- 292 Service & License
- 4.6K FAQ
