給顧客的無線網路"1.1.1.1"被認為不安全連接
Hi @txyam,
1. Create a self-signed certificate.
Go to CONFIGURATION > Object > Certificate > My Certificates > Add.
Enter the profile name and the IP address 192.168.1.1.
Select the Server “Authentication” and “Create a self-signed certificate”.
2. Open the profile again. Click “Export Certificate Only”.
3. Change Server certificate that you just created and enable “Redirect HTTP to HTTPS”.
Go to CONFGIGURATION > System > WWW > Service Control > HTTPS.
4. Right click the certificate and install the certificate on the laptop.Go Next on the first installation page and select the “Trusted Root Certificate Authorities” to save the certificate.
5. Result
Hi 您好
謝謝您的回答,我照著您的指示做了,所以最後,是每一位顧客都需要安裝我們的Certificate嗎?
如果是這樣,我的問題還是沒有解決。
(因為我們的客人是很少能夠有這能力的)所以我的解決方法是,告訴顧客,他們先要把我們的ip 192.168.1.1在顧客的電腦上exploer設定為trust ip, 或是先暫時關閉他們的防火牆,連接192.168.1.1 login 後再打開他們電腦的防火牆。
如果我解錯誤了請您告訴我。
謝謝您的寶貴時間
Danny
Hi @txyam,
You can also purchase a valid third-party certificate and import it to CONFIGURATION > Object > Certificate > Trusted Certificates.
The ZyWALL requires one ROOT certificate in Trusted Certificates to authenticate the third-party organization and one purchased certificate in My Certificates.
- 430 Beta Program
- 2.6K Nebula
- 163 Nebula Ideas
- 6K Security
- 355 USG FLEX H Series
- 292 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 261 Service & License
- 407 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 82 Security Highlight
