給顧客的無線網路"1.1.1.1"被認為不安全連接
txyam
txyam Posts: 8 image  Freshman Member
edited April 2021 in Security
我要請問您
我買了Zywall110也買了HOTspot management 軟體,也設定好了,可印出login ticket , 顧客可以使用手機login, 但電腦login 時,電腦的防火牆都會認為我的zywall 192.168.1.1 或 1.1.1.1是個不安全的網路,所以不能打開login page, 我如何把我的Zywall 設定成安全網頁?這和設定SSL 有關嗎?
謝謝
  • Zyxel_Emily
    Hi @txyam,
    1. Create a self-signed certificate.
    Go to CONFIGURATION > Object > Certificate > My Certificates > Add.
    Enter the profile name and the IP address 192.168.1.1.
    Select the Server “Authentication” and “Create a self-signed certificate”.
    2. Open the profile again. Click “Export Certificate Only”.
    3. Change Server certificate that you just created and enable “Redirect HTTP to HTTPS”.
    Go to CONFGIGURATION > System > WWW > Service Control > HTTPS.
    4. Right click the certificate and install the certificate on the laptop.Go Next on the first installation page and select the “Trusted Root Certificate Authorities” to save the certificate.
     5. Result
  • txyam
    Hi 您好
    謝謝您的回答,我照著您的指示做了,所以最後,是每一位顧客都需要安裝我們的Certificate嗎?
    如果是這樣,我的問題還是沒有解決。
    (因為我們的客人是很少能夠有這能力的)所以我的解決方法是,告訴顧客,他們先要把我們的ip 192.168.1.1在顧客的電腦上exploer設定為trust ip, 或是先暫時關閉他們的防火牆,連接192.168.1.1 login 後再打開他們電腦的防火牆。
    如果我解錯誤了請您告訴我。
    謝謝您的寶貴時間
    Danny
  • Zyxel_Emily
    Hi @txyam,
    You can also purchase a valid third-party certificate and import it to CONFIGURATION > Object > Certificate > Trusted Certificates.
    The ZyWALL requires one ROOT certificate in Trusted Certificates to authenticate the third-party organization and one purchased certificate in My Certificates.
