ATP 200 SSL Inspection error
Ceccus
Ceccus Posts: 46 image  Freshman Member
edited April 2021 in Security
on my ATP 200 I activated SSL Inspection.
After updating to MAC OSX 10.15 Catalina I get this error:
NET::ERR_CERT_WEAK_KEY
I use the default certificate.
With the previous version 10.14 it worked fine.
Browser : Chrome and Safari , latest version.
Is the problem due to this?
https://www.macrumors.com/2019/06/06/apple-deprecates-sha1-macos-catalina-ios-13/
https://support.apple.com/en-us/HT210176
How to solve? Thanks
Regards
«1
  • Alfonso
    Alfonso Posts: 257 image  Master Member
    edited October 2019
    Hi @Ceccus
    Welcome to the forum.
    I suspect you are right.
    So I recommend generating new certificates and upload them as the following KB explains:
    https://kb.zyxel.com/KB/searchArticle!gwsViewDetail.action?articleOid=003075&lang=EN
    I hope it helps.
    Regards
  • Ceccus
    Thanks for the reply.
    I think the problem is generalized and I also think that Zyxel should remedy by making a new certificate available
    Regards
  • Alfonso
    Hi @Ceccus
    Obviously Zyxel can recreate a new certificate, but I suppose it requires a device upgrade ...
  • Ceccus
    Firmware upgrade ... i suppose.
    Regards
  • Zyxel_Emily
    Hi @Ceccus,
    Thanks for reporting.
    It is confirmed as a bug.
    We are working on fixing it. I will send the firmware to you for verification after the bug is fixed.
  • Ceccus
    Thank you so much
    Waiting for the Fix
    Regards
  • Ceccus
    Hi Emily,
    How long will the Fix be available?
    Regards
  • Zyxel_Emily
    Hi @Ceccus,
    We modify the format of entries in the certificate to satisfy the requirements of MacOS 10.15 and it is still under verification.
    I will update the test results in the near future.
  • Zyxel_Emily
    Hi @Ceccus,
    The firmware is sent to you in the private message.
  • Ceccus
    problem still open ... firmware slow in SSL Inspection.
    Any ideas ?
