i can't use ssl vpn for connect my usg
I have a truble with secuextender software, not a secuextender vpn client software. The connection to the USG it's alive but i can't ping from my pc any device on the remote lan.
I see in the traffic status in the "packet receive" 0 data
how can i solved it?
Thankyou
Elaborating a bit more your current configuration? Maybe something is still wrong...
Hi @simetec,
Make sure the USG is upgraded to 4.35.
Here are some FAQ for your reference.
If you still has questions about SSL VPN, share the topology with IP/subnet and screen shots of SSL VPN related settings with us.
SecuExtender 4.0.3.0 for Windows failed to access ZyWALL's LAN
- 440 Beta Program
- 292 Service & License
- 4.6K FAQ
