ATP 200 VPN How to?
Username_is_reserved
Username_is_reserved Posts: 115  Ally Member
edited April 2021 in Security
Hi
Can someone recommend a How to Setup a VPN Connection between a Win7, Win10, Android Device,.. with an ATP200?
For my old USG300 was some avaiable and since I am not a Pro I dont find the right Box to select and the are maybe not secured.
