ATP 200 VPN How to?
Username_is_reserved
Hi
Can someone recommend a How to Setup a VPN Connection between a Win7, Win10, Android Device,.. with an ATP200?
For my old USG300 was some avaiable and since I am not a Pro I dont find the right Box to select and the are maybe not secured.
You can use the wizard to configure L2TP VPN on ATP200.
Here are some FAQs for your reference.
How to use the VPN Setup Wizard to create a L2TP VPN on the ZyWALL/USG
How do you configure L2TP VPN between ZyWALL and a Windows 7 laptop?
Thanks, I'm setting up for the first time also. Does it matter if my DHCP server is on a windows server rather than the Zyxel?
What I know from my USG 300 theoretically not.
When the VPN Tunnel is connected you are in the Network and theoretically the Win Server should able to deliver an IP Address.
- 435 Beta Program
- 176 Nebula Ideas
- 425 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 419 News and Release
- 89 Security Highlight
