USG 20W upgrade old firmware
Liam_McCallum
Liam_McCallum Posts: 1 image  Freshman Member
edited April 2021 in Security
I have a Zyxel USG 20W with firmware 3.30(BDR.7) and would like to upgrade it to the latest version. I can only find firmware for the model USG 20W-VPN firmware version 4.35(ABAR.0).
I attempted the upgrade to the device but received and error saying the firmware was incompatible. I am not sure if this is because my device is a different model (note that -VPN is missing in the model number on my device) or because the jump from 3.30 to 4.35 is to big. Or both. I may also be a separate issue altogether.
Any guidance on next best steps would be appreciated.
  • Zyxel_Emily
    Hi @Liam_McCallum,
    ZyWALL USG 20W doesn’t support firmware 4.35.
    Here are firmware 4.35 supported models.
    ZyWALL USG Firewall
    ZyWALL 110/ ZyWALL 310/ ZyWALL 1100/ USG20-VPN/ USG20W-VPN/ USG40/ USG40W/ USG60/ USG60W/ USG110/ USG210/ USG310/ USG1100/ USG1900/ USG2200 Series
    ATP Firewalls
    ATP100/ATP200/ATP500/ATP800
  • mMontana
    mMontana Posts: 1,468 image  Guru Member
    Latest USG20W firmware should be BDR.9.
  • Enrico84
    Enrico84 Posts: 3 image  Freshman Member
    Good morning, sorry if I intrude.
    I can't backup my zyxel atp800, I can't find it on my atp800.
    how can I make a full backup of my firewall?
    Thank you
  • Zyxel_Jerry
    Zyxel_Jerry Posts: 1,406 image  Zyxel Employee
    Hi @Enrico84
    Welcome to Zyxel Community
    The startup-config.conf file is the configuration file that the Zyxel Device is currently using.
    Go to Maintenance > File Manager > Configuration File to copy the startup-config.conf file.
    You can refer to the user guide to backup the configuration file.
    The information is on page 809 Chapter 40 File Manager Table 352
    ftp://ftp2.zyxel.com/ATP800/user_guide/ATP800_V4-35_ED1.pdf
