shutdown
Franc
Franc Posts: 27 image  Freshman Member
edited April 2021 in Security
is there a way to shutting down the USG60 without doing the standard steps via browser (login>maintenance>reboot) ?
In event of electrical supply trouble I'd like to switch off the firewall very quickly to prevent hardware damages (I have already replaced TWO USG 100 for this reason!)
For example, it would be wonderful from my smarthphone have a special link to run directly the shutting down.
Any ideas or suggestion?
Best regards
«1
  • Franc
    edited November 2019
    Thank-you very much @mMontana @lalaland @Zyxel_Emily
    Best regards
    PeterUK Posts: 4,359 image  Guru Member
    Maybe you should look at getting a UPS.
  • Franc
    I have the UPS of course.
    But the right question is why these pro devices don’t support an ups link!
    I am pretty angry because these firewalls are too delicate, just a few sudden stops to damage them.
  • mMontana
    mMontana Posts: 1,447 image  Guru Member
    Scripting a terminal emulator? Never tried but could be possible.
  • lalaland
    lalaland Posts: 91 image  Ally Member
    First Answer First Comment Friend Collector Sixth Anniversary
    edited October 2019
    How about using python script to perform this task, and add it to windows scheduler run?
    Please don't run this script from wan since it is just simple telnet without encryption.
    (Replace them with your device ip, ID, and password.
    ----------------------------shutdown.py-------------------------------------
    import telnetlib
    #Log in info
    USG_IP = "192.168.2.1"
    ID = "admin"
    Password = "12345"
    tn = telnetlib.Telnet(USG_IP, timeout=1)
    #Set debug level if need
    #tn.set_debuglevel(2)
    #Telnet Log In
    tn.read_until("Username:")
    tn.write(ID + "\n")
    tn.read_until("Password:")
    tn.write(Password + "\n")
    #Put your command here
    tn.write("shutdown\n")
    tn.write("exit\n")
    #print
    print tn.read_all()
  • Franc
    Thank-You @lalaland and @mMontana ! It sounds very good and it may works also in a mobile app. It would be great to swith off the firewall from the smartphone.
    On USG 60 side, how can I enable the telnet script reception?
  • mMontana
    Suggest SSH not Telnet outside LAN1.
  • lalaland
    @Franc , Enable Telnet at "Configuration > System > Telnet"?
  • Franc
    thank-you very much guys I'll try and I let you know
  • Franc
    Hi @lalaland and @mMontana
    As you suggested I try with SSH, no third party client needed on MacOS.
    I successfully logged in via SSH and I simply wrote "shutdown". The USG immediately has switched off. Very good!!
    I wrote:
    "ssh username@host"
    "password"
    "shutdown"
    One more thing, is this way a RIGHT way to switch off the USG as the standard way via web interface? Or rather, does the USG switch off correctly without damages?
    Thank-you very much!
