USG60 rebooting with WK30 fall back to LastGood
USG60, 4.33 as standby firmware, 4.33 WK30 as default.
I edited the configuration:
- Added a group of services
- Changed a description of user3
- Changed password of a user2
- Changed groups for user1 and user2
- Used a group of services for a Security policy
If i reboot with this "modified" configuration, the Firewall falls back to last good. Every time.
Now i rebooted on 4.33 for edit the configuration and try a reboot
Sorry for the delay. After the issues for upgrade a couple of devices, I waited to visit premises of USG60.
@Zyxel_Cooldia corrected the USG60 configuration for me about 5 weeks ago, and it run quite smoothly on 4.33WK30 until yesterday.
I rebooted to standby 4.33 firmware, which went good. Then upgraded WK30 manualy to 4.35 quite flawlessly.
And now: case solved.
I forgot also the update/add of a IkeV2 gateway...
After rebooting on 4.33, edit the configuration, added a Ikev2 gateway. Then rebooted on 4.33, without any issue.
Rebooting to 4.33WK30, Ikev2 gateway disappeared.
Which failed blatantly.
After editing the configuration, reboot on 4.33 (finding the correct configuration updated), the next reboot on 4.33 WK30 wiped all my edits. This is quite bad...
Hi @mMontana ,
Can you send me your configuration file via private message? Let me have a quick test on your configuration file.
Done.
Any news?
Problem is completely unrelated with the firmware. Configuration seems to have two or more malformed objects (IPSec Gateway, user) which are "trippin" the firewall during the reboot.
I'll double check the setup for reboot test ASAIC.
- 435 Beta Program
- 176 Nebula Ideas
- 425 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 419 News and Release
- 89 Security Highlight
